This guide contains all permissions and requirements for connecting your Bluesky data to Supermetrics.
The Bluesky Public Data connector connects directly to the public AT Protocol API (api.bsky.app) without needing any authentication or special access permissions.
User profile: Provides the current status of a profile (no date range needed). Requires one Bluesky handle.
User posts: Retrieves an author feed (including reposts) alongside engagement metrics over a specified date range. Requires one Bluesky handle.
Followers: Retrieves the active list of followers (no date range needed). Requires one Bluesky handle.
Following: Retrieves the active list of accounts being followed (no date range needed). Requires one Bluesky handle.
When connecting to Bluesky Public Data, enter the target Bluesky handle using either the username.bsky.social or username format.
Select the Bluesky Public Data data source on the Supermetrics Hub or in the data destination.
In your data destination, select a query type, if prompted, and enter the Bluesky handle to include in your reporting.
You can also connect to Bluesky Public Data from these destinations:
AI tools and dashboards:
