Beeswax connection guide
This guide contains all permissions and requirements for connecting your Beeswax data to Supermetrics.
To pull data from Beeswax, you need a Beeswax username, password, and the buzz key. The buzz key is a part of your page URL in Beeswax: https://(yourbuzzkey).beeswax.com.
  • Performance: Fetch performance data for your campaigns on daily level
When connecting to Beeswax, you need to enter your credentials and select the account to pull data from when prompted.
  1. Select the Beeswax data source on the Supermetrics Hub or in the data destination.
  2. Enter your buzz key, username, and password.
  4. Click Start.
  5. In your data destination, select the account to pull data from and a query type, if prompted.
You can also connect to Beeswax from these destinations:
