This guide contains all permissions and requirements for connecting your Axon by AppLovin data to Supermetrics.
Before using the Axon by AppLovin connector, you need your API key from the AppLovin platform. To obtain the API key, navigate to the Keys tab of the account page in your AppLovin dashboard.
How to generate an API Key
Log in to Axon and go to the API Keys tab on your account page.
Click + New API Key.
Give the API key a descriptive name to easily identify it, for example, “Supermetrics”.
Copy and securely store the new API key immediately. For security reasons, it won’t be shown again.
Performance: Fetch performance data for your advertising campaigns.
When connecting to Axon by AppLovin, you need your API key for the connection.
Select the Axon by AppLovin data source on the Supermetrics Hub or in the data destination.
Enter the API key and give a name for your login.
In your data destination, select the ad accounts to include in your reporting and a query type, if prompted.
You can also connect to Axon (AppLovin) from these destinations:
AI tools and dashboards:
