Awin connection guide
This guide contains all permissions and requirements for connecting your Awin data to Supermetrics.
To connect Supermetrics to Awin, you need Awin API credentials.
  1. Go to the Awin API credentials page.
  2. Enter your Awin password and click Show my API token.
  3. Copy the API token.
Learn more about how to create these credentials in the Awin wiki.
  • Publisher report: Get aggregate performance metrics, like impressions and transactions, per publisher.
  • Creative report: Fetch aggregate performance metrics, like impressions and transactions, per creative used.
  • Transactions report: Pull all individual transactions to check their status and commissions paid.
When connecting to Awin, you need to insert your API key (API token) and select the accounts and query type to use when prompted.
  1. Select the Awin data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key.
  5. Click Start.
  6. In your data destination, select the accounts and query type to use.
You can also connect to Awin from these destinations:
