Adjust connection guide
This guide contains all permissions and requirements for connecting your Adjust data to Supermetrics.
To connect Supermetrics to Adjust, you'll need an API token to access your Adjust account. In Supermetrics, each Adjust app is considered an account, and you need to select the right Adjust app to use when querying data.
Get your API token
  1. Log in to Adjust and open your dashboard.
  2. Click the menu in the top left corner to open the sidebar.
  3. In the bottom left, click My profile.
  4. In the right sidebar, click API token.
  5. Copy the API token, and keep it secure.
  • Datascape
When connecting to Adjust, you need to insert your API token and app key when prompted.
  1. Select the Adjust data source on the Supermetrics Hub or in the data destination.
  2. Enter your API token.
  5. Click Start.
  6. In your data destination, select the query type to use, if prompted.
You can also connect to Adjust from these destinations:
