This guide contains all permissions and requirements for connecting your ActiveCampaign data to Supermetrics.
Before using the ActiveCampaign connector, you need a copy of your API URL and API key and appropriate permissions for data access on your account.
Set user permissions
Depending on your needs, your account needs access to the following objects in ActiveCampaign:
Campaigns
Deals
Accounts
Contacts
You can set these permissions for users and groups in ActiveCampaign's admin settings. To get data on your report, select all permissions for the object. Learn how to set user permissions in ActiveCampaign.
If you're an admin user, make sure that you have the necessary permissions. If not, add yourself to a permission group with the necessary permissions.
Get your API URL and API key
Each user in ActiveCampaign has their own API URL and API key. To get these:
Log into ActiveCampaign with your account.
Navigate to Settings → Developer.
Copy the URL and key from the API Access section.
Campaigns report: Follow the performance of your email campaigns. This report fetches data for regular campaign emails as well as automation emails. Automation emails can be identified by the value in the “Automation ID” dimension.
Deals report: Track the status of your sales deals.
Accounts report: Fetch details of your customer accounts.
Contacts report: Fetch details about your contacts.
When connecting to ActiveCampaign, you need to log provide your API URL and API key.
Select the ActiveCampaign data source on the Supermetrics Hub or in the data destination.
Enter the API URL and API key.
Give your login a name to recognize the login later in case you have multiple logins.
In your data destination, select the accounts and query type to use.
You can also connect to ActiveCampaign from these destinations:
