LY Ads Search Ads connection guide
This guide contains all permissions and requirements for connecting your Yahoo! Japan Search Ads data to Supermetrics.
You need a Yahoo! Japan business account to connect to Supermetrics.
When connecting to Yahoo! Japan Search Ads, you need to log in to Yahoo! Japan.
  1. Select the Yahoo! Japan Search Ads data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Enter your Yahoo! Japan business account credentials.
  5. Click Login, and then Approve.
You can also connect to Yahoo! Japan Search Ads from these destinations:
