The Trade Desk connection guide
This guide contains all permissions and requirements for connecting your The Trade Desk data to Supermetrics.
To connect Supermetrics to The Trade Desk, you need the Partner-level reporting user role and access to partner cost metrics. There might be fees associated with API access that you'll pay to The Trade Desk.
Note that you'll need to sign a form with The Trade Desk to grant access to your data. Like any third-party supplier, Supermetrics isn't involved with the creation of this document.
When connecting to The Trade Desk, you need to log in to The Trade Desk and select the timezone when prompted.
  1. Select the The Trade Desk data source on the Supermetrics Hub or in the data destination.
  2. Enter your email address, password, and timezone. The timezone must match your The Trade Desk account's timezone setting.
  4. Click Start.
  5. In your data destination, select the timezone.
You can also connect to The Trade Desk from these destinations:
