Similarweb connection guide
This guide contains all permissions and requirements for connecting your Similarweb data to Supermetrics.
You need to create an API key to connect Supermetrics to your Similarweb account. Note that only account admins can generate new API keys in Similarweb.
To create the API key:
  1. Log in to the Similarweb platform.
  2. From the left menu, select Settings > Account.
  3. Under API, select Standard API.
  4. Click Generate a new API key
  5. Select the primary user of the API key you're creating.
  6. Click Create. Your key will be displayed in the Generated Keys table.
  • Traffic and engagement: Get the traffic volume and engagement for one or multiple websites.
  • Desktop traffic sources: Understand what channels visitors are coming from for one or multiple websites. Only returns data for desktop users.
  • Search keyword competitors: Analyze what the biggest competing websites are on search engines, for one or multiple websites.
  • Top sites: Get ranking data for the top websites in a selected industry.
  • App performance: Get the overall rating and rank of any mobile app in the Google Play Store or the Apple App Store.
When connecting to Similarweb, you need to provide your credentials and select the query type to use.
  1. Select the Similarweb data source on the Supermetrics Hub or in the data destination.
  2. Enter your API Key.
  5. Click Start.
  6. In your data destination, select a query type to use.
You can also connect to Similarweb from these destinations:
