Reddit Ads connection guide
This guide contains all permissions and requirements for connecting your Reddit Ads data to Supermetrics.
You need a Reddit account and access to the ad accounts from which to want to pull data.
  • Main report: Fetch performance, conversions, and video metrics from your Reddit Ads campaigns.
When connecting to Reddit Ads, you need to log in to Reddit and select the account to use when prompted.
  1. Select the Reddit Ads data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Log in to your Reddit account.
  5. Click Allow to allow the Supermetrics app to access your profile data.
  6. In your data destination, select the account to pull data from and a query type, if prompted.
You can also connect to Reddit Ads from these destinations:
