Pinterest Organic connection guide
This guide contains all permissions and requirements for connecting your Pinterest Organic data to Supermetrics.
Note
We released a new version of the Pinterest Organic data source connector on June 1, 2023, with some changes to the authentication process.
To connect to Pinterest Organic, you need a Pinterest business account and an ad account.
With a Pinterest business account and ad account, you can fetch organic data for your own Pinterest profile. Before starting the connection process in Supermetrics, make sure that you're logged into a Pinterest business account in your web browser and not a personal Pinterest account.
Important about authentication
When authenticating, if you receive an error saying We did not find any accounts, please make sure you have created an ad account for your Pinterest business account.
Employee and Partner access
To fetch organic data for another Pinterest account, you must be added as an Employee or Partner to their business account and have at least Analyst access to one of their ad account.
  • Profile: Get aggregated organic metrics of all pins and lifetime metrics of the profile. This report contains analytics from your owned pins (created and saved by you), as well as pins created and saved by others from your claimed accounts, such as websites.
  • Top pins: Get organic metrics for the top 50 pins. This report contains analytics from your owned pins (created and saved by you), as well as pins created and saved by others from your claimed accounts, such as websites.
  • Owned pins: Get organic metrics for your owned pins (created and saved by you) with daily breakdowns.
When connecting to Pinterest Organic, you need to log in to Pinterest and select the accounts to pull data from when prompted.
  1. Select the Pinterest Organic data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Enter your email address and password, and click Log in.
  5. Click Give access.
  6. Select the accounts you'd like to include in your reporting.
  7. In your data destination, select the query type to use.
You can also connect to Pinterest Organic from these destinations:
