Piano Analytics (AT Internet) connection guide
This guide contains all permissions and requirements for connecting your Piano Analytics (AT Internet) data to Supermetrics.
Before using the Piano Analytics (AT Internet) connector, you must get your site ID as well as an access key and secret key.
Get your site ID
  1. Log in to Piano Analytics (AT Internet).
  2. Open the Data Query feature.
  3. Select the “Site ID” as the row and “Visits” as the column.
  4. Click the arrow on the right side to launch the query.
  5. Your site ID should now be visible in the table. Copy and save this number.
  6. If you have multiple sites that you want to report for, copy and save each one.
Get your access key and secret key
  1. In "Piano Analytics (AT Internet)", go to your profile page.
  2. Select the API Keys tab.
  3. Select Create a new API Key.
  4. Give any name for this key, for example, “Supermetrics”.
  5. Click Create a new API Key.
  6. Copy the access key and secret key to a safe place.
  7. Click OK.
  • Performance report: Analytics data for your website, including metrics for acquisition and on-site behavior.
When connecting to Piano Analytics (AT Internet), you need to provide the site ID, access key, and secret key.
  1. Select the Piano Analytics (AT Internet) data source on the Supermetrics Hub or in the data destination.
  2. Enter the site ID that you want to report for. You can enter one site as “12345”, or multiple sites separated by commas: “12345,56342,23444”.
  3. Enter your access key and secret key.
  4. Give your login a name to recognize the login later in case you have multiple logins.
  6. Click Start.
You can also connect to Piano Analytics (AT Internet) from these destinations:
