Moloco DSP connection guide
This guide contains all permissions and requirements for connecting your Moloco DSP data to Supermetrics.
To connect to Moloco DSP connector, you need an API key.
To create an API key:
  1. Sign in to Moloco Ads with your unique sign in credentials.
  2. Click API Access below User settings.
  3. Click Create API Key to generate an API key for the workplace.
  • Performance report:  Fetch analytics data for your ads.
When connecting to Moloco DSP, you need to provide your Moloco API key.
  1. Select the Moloco DSP data source on the Supermetrics Hub or in the data destination.
  2. Insert your Moloco DSP API key and give a name for your login.
  4. Click Start.
  5. In your data destination, select the account to use in your reporting, and a query type to use, if prompted.
You can also connect to Moloco DSP from these destinations:
