Meltwater connection guide
This guide contains all permissions and requirements for connecting your Meltwater data to Supermetrics.
To use this connector, you need:
  • Access to the Meltwater API as part of your Meltwater subscription
  • A Meltwater API token
You can create and get your API token by following these steps:
  1. In Meltwater, go to AccountMeltwater API in the left-hand navigation.
  2. If you do not have an existing API token, click Generate API token. Meltwater states that you can only have one API token at any time.
  3. After you have generated the API token, you can enter a name for it.
  4. Remember to copy the API token and store it securely since it is not possible to access the token in the future.
Learn more about Meltwater API credentials in Meltwater's documentation.
  • Export media: Pull social listening data from your saved Searches in Meltwater.
When connecting to Meltwater, you need to provide your API token.
  1. Select the Meltwater data source on the Supermetrics Hub or in the data destination.
  2. Insert your API token.
  3. Give a name for your login.
  5. Click Start.
  6. In your data destination, select the saved searches to use.
You can also connect to Meltwater from these destinations:
