Lazada Ads connection guide
This guide contains all permissions and requirements for connecting your Lazada Ads data to Supermetrics.
To connect your Lazada Ads data to Supermetrics, you need a Lazada account.
  • Sponsored Discovery: Pull performance data from Lazada Ads, based on the campaign and promoted product
When connecting to Lazada Ads, you need to log into Lazada and select the accounts to pull data from.
  1. Select the Lazada Ads data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Select the Lazada Site location from the dropdown menu.
  5. Log in with the account you use to log in to Lazada.
  6. Click Submit.
  7. In your data destination, select the the stores to include in your reporting and a query type, if prompted.
You can also connect to Lazada Ads from these destinations:
