This guide contains all permissions and requirements for connecting your Klaviyo data to Supermetrics.
To connect to Supermetrics, your Klaviyo account needs one of these user roles:
Admin
Owner
Manager
Learn more about user management and privileges in Klaviyo's documentation.
When connecting to Klaviyo, you will need to log in with your Klaviyo user account and select the ad account to pull data from when prompted.
Select the Klaviyo data source on the Supermetrics Hub or in the data destination.
Fill in the Email and Password fields with your Klaviyo account details.
Check the I’m not a robot box to pass the reCaptcha.
Click Log in.
There will be a warning that the app is not approved. This is okay — Supermetrics is in the process of getting our Klaviyo app approved with the Klaviyo team. Click Continue.
Review and approve the permissions for the app by clicking Allow.
In your data destination, select the accounts to include in your query.
You can also connect to Klaviyo from these destinations:
AI tools and dashboards:
