Impact connection guide
This guide contains all permissions and requirements for connecting your Impact data to Supermetrics.
Before using the Impact connector, you need a copy of your account SID and auth token.
To get the account SID and auth token:
  1. Log in to the Impact.com platform.
  2. From the bottom left, navigate to Settings.
  3. Under Technical, navigate to API.
  4. Under the API Access tab, you can find your Account SID and Auth Token.
Scopes
The following scopes are required to pull data from Impact:
Scope
API path
Method
Accounts
/Advertisers/<Account SID>/CompanyInformation
GET
Actions
/Advertisers/<Account SID>/Actions
GET
Campaigns
/Advertisers/<Account SID>/Campaigns
GET
Media partners
/Advertisers/<Account SID>/MediaPartners
GET
API submissions
/Advertisers/<Account SID>/APISubmissions
GET
Report exports
/Advertisers/<Account SID>/ReportExport/adv_performance_by_ad_media_date
GET
Report exports
/Advertisers/<Account SID>/ReportExport/att_adv_performance_by_mp_gr
GET
Report exports
/Advertisers/<Account SID>/ReportExport/att_adv_performance_by_geo_location_pm_only
GET
Report exports
/Advertisers/<Account SID>/ReportExport/adv_action_listing_pm_only
GET
  • Performance by Ad / Partner / Date: Get performance data aggregated on an ad, partner, and daily level.
  • Performance by Partner group: Get performance data aggregated on the partner group level. This report only returns data for Partners that are part of a Partner group.
  • Performance by Country: Get performance data aggregated on the country level.
  • Advanced action listing: List all actions and their details generated in a selected date range.
When connecting to Impact, you need your account SID and auth token.
  1. Select the Impact data source on the Supermetrics Hub or in the data destination.
  2. Enter your account SID and auth token.
  5. Click Start.
  6. In your data destination, select a query type to use, if prompted.
You can also connect to Ignite from these destinations:
