This guide contains all permissions and requirements for connecting your Impact data to Supermetrics.
Before using the Impact connector, you need a copy of your account SID and auth token.
To get the account SID and auth token:
Log in to the Impact.com platform.
From the bottom left, navigate to Settings.
Under Technical, navigate to API.
Under the API Access tab, you can find your Account SID and Auth Token.
Performance by Ad / Partner / Date: Get performance data aggregated on an ad, partner, and daily level.
Performance by Partner group: Get performance data aggregated on the partner group level. This report only returns data for Partners that are part of a Partner group.
Performance by Country: Get performance data aggregated on the country level.
Advanced action listing: List all actions and their details generated in a selected date range.
When connecting to Impact, you need your account SID and auth token.
Select the Impact data source on the Supermetrics Hub or in the data destination.
Enter your account SID and auth token.
In your data destination, select a query type to use, if prompted.
You can also connect to Ignite from these destinations:
