Hubspot Marketing Forms connection guide
This guide contains all permissions and requirements for connecting your HubSpot Marketing Forms data to Supermetrics.
User permissions
You must have sufficient permissions in HubSpot to install and authorize the app. One of the following roles is required:
  • Admin
  • Owner (full access)
Supported products
To use the HubSpot Marketing Forms data source, you need one of the following HubSpot products or higher:
  • Marketing Hub - Free
  • Sales Hub - Free
  • Service Hub - Free
  • Content Hub - Free
  • Data Hub - Free
When connecting to HubSpot Marketing Forms, you need to log in to HubSpot and select the portal to use when prompted.
  1. Select the HubSpot Marketing Forms data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Log in with your HubSpot details once prompted. If you're currently logged into a HubSpot account, Supermetrics will use those credentials to authenticate your connection.
  5. Choose which portal to authorize with.
  6. Click Allow to allow the Supermetrics app to access your data.
You can also connect to HubSpot Marketing Forms from these destinations:
