Google Merchant Center connection guide
This guide contains all permissions and requirements for connecting your Google Merchant Center data to Supermetrics.
You must have both the Standard and Reporting manager permissions in the Google Merchant Center account you want to pull data from.
  • Performance: Retrieve merchant performance metrics matching the search query and optionally segmented by selected dimensions.
  • Product: Offers an overview of all your products.
  • Diagnostics: Offers issue reporting across your account and items grouped by the context in which your product data might show.
When connecting to Google Merchant Center, you need to log in to Google and select the account to use.
  1. Select the Google Merchant Center data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Select the Google account associated with your Google Merchant Center account where you want to fetch data from.
  5. Click Allow to allow the Supermetrics app to access your profile data.
  6. In your data destination, select the query type to use.
You can also connect to Google Merchant Center from these destinations:
