This guide contains all permissions and requirements for connecting your Google Ads data to Supermetrics.
You need a Google Ads or manager account with Read Only access. Learn how to grant access to a Google Ads account or manage your accounts.
If you have connected to Google Ads correctly, but your ad account doesn't appear, try granting the manager account access again.
You need to set up a passkey for your Google Ads account to complete the authentication. Read more about passkeys in Google’s help.
When connecting to Google Ads, you need to log in to Google and select the accounts to pull data from when prompted.
Select the Google Ads data source on the Supermetrics Hub or in the data destination.
Click Sign in with Google.
Sign in with the Google Account you use with this data source. This doesn't have to be the same as the Google Account you use with Supermetrics. Use your passkey when prompted, and click Continue.
Select all access scopes and click Allow. Failure to select all may result in the data source not functioning correctly.
In your data destination, select the accounts to pull data from.
You can also connect to the Google data sources from these destinations:
AI tools and dashboards:
Spreadsheet and visualization tools:
