Gong connection guide
This guide contains all permissions and requirements for connecting your Gong data to Supermetrics.
Before using the Gong connector, you’ll need an Access Key, an Access Key Secret, and your base URL.
How to find your base URL and create an API Access Key
  1. Log in to your Gong account with a user who has at least Technical Administrator permissions.
  2. Navigate to the Gong API page in the Admin center.
  3. The Base URL for all API calls will be visible in the top section of the page. Copy this URL for later use.
  4. Click Create to generate new API credentials.
  5. The Access Key and Access Key Secret will only be shown once. Copy these to a secure location for later use.
  • Calls: Retrieve detailed insights on your sales calls.
  1. Select the Gong data source on the Supermetrics Hub or in the data destination.
  2. Enter your Gong Base URL, Access Key, Access Key Secret, and give a name for your login, “Supermetrics for example”.
  4. Click Start.
  5. In your data destination, select the account to pull data from and a query type, if prompted.
You can also connect to Gong from these destinations:
