This guide contains all permissions and requirements for connecting your DoubleVerify data to Supermetrics.
To connect Supermetrics to your DoubleVerify account, you need to create an access token.
Log in to the DoubleVerify platform.
In the top navigation bar, hover the cursor over Analytics and click Data API.
Click Create new token.
Select the Reporting Programs you want to fetch data from.
Click Create.
Copy the Access Token Hash and store it in a secure place for later use.
DoubleVerify query types
Standard report
Universal: General metrics on how many ads were monitored, considered authentic or blocked.
Brand suitability: Metrics to understand the brand safety level of ads.
Fraud/SIVT: Measurement of fraud level, impressions that were recorded as bot fraud, site fraud, nonhuman data center traffic and injected ad events.
Geo: Metrics to follow if ads delivered were in or out of the intended geography.
Display viewability: Viewability metrics for display ads.
Video viewability: Viewability metrics for video ads.
Meta (Proprietary Media Gardens) report
Viewability: Viewability metrics for ads.
TikTok (Proprietary Media Gardens) report
Brand suitability: Measurement of brand safety and suitability.
Geo: Geo metrics for ads.
Snapchat (Proprietary Media Gardens) report
Twitter (Proprietary Media Gardens) report
YouTube (Proprietary Media Gardens) report
When connecting to DoubleVerify, you need to enter your access token and select the account timezone to use when prompted.
Select the DoubleVerify data source on the Supermetrics Hub or in the data destination.
Enter your access token.
In your data destination, select the account, timezone, and query type to use, if prompted.
You can also connect to DoubleVerify from these destinations:
