DoubleVerify connection guide
This guide contains all permissions and requirements for connecting your DoubleVerify data to Supermetrics.
To connect Supermetrics to your DoubleVerify account, you need to create an access token.
  1. Log in to the DoubleVerify platform.
  2. In the top navigation bar, hover the cursor over Analytics and click Data API.
  3. Click Create new token.
  4. Select the Reporting Programs you want to fetch data from.
  5. Click Create.
  6. Copy the Access Token Hash and store it in a secure place for later use.
DoubleVerify query types
  • Standard report
    • Universal: General metrics on how many ads were monitored, considered authentic or blocked.
    • Brand suitability: Metrics to understand the brand safety level of ads.
    • Fraud/SIVT: Measurement of fraud level, impressions that were recorded as bot fraud, site fraud, nonhuman data center traffic and injected ad events.
    • Geo: Metrics to follow if ads delivered were in or out of the intended geography.
    • Display viewability: Viewability metrics for display ads.
    • Video viewability: Viewability metrics for video ads.
  • Meta (Proprietary Media Gardens) report
    • Viewability: Viewability metrics for ads.
  • TikTok (Proprietary Media Gardens) report
    • Brand suitability: Measurement of brand safety and suitability.
    • Geo: Geo metrics for ads.
  • Snapchat (Proprietary Media Gardens) report
  • Twitter (Proprietary Media Gardens) report
  • YouTube (Proprietary Media Gardens) report
When connecting to DoubleVerify, you need to enter your access token and select the account timezone to use when prompted.
  1. Select the DoubleVerify data source on the Supermetrics Hub or in the data destination.
  2. Enter your access token.
  5. Click Start.
  6. In your data destination, select the account, timezone, and query type to use, if prompted.
You can also connect to DoubleVerify from these destinations:
