Criteo connection guide
This guide contains all permissions and requirements for connecting your Criteo data to Supermetrics.
To connect Supermetrics to Criteo, you need:
  • An API user with a client ID and client secret
  • An app with at least Read access for all elements of the Marketing API.
    • If you're logged with an old Criteo app, you'll need to log out of Criteo and then log back again.
See our Criteo permissions guide for instructions on how to generate the credentials and the app as well as how to install a new Criteo app.
When connecting to Criteo, you need to enter your client ID and client secret and select the accounts to use in your reporting when prompted.
  1. Select the Criteo data source on the Supermetrics Hub or in the data destination.
  2. Enter your Criteo client ID and client secret.
  4. Click Start.
  5. In your data destination, select the accounts to use in your reporting.
You can also connect to Criteo from these destinations:
