This guide contains all permissions and requirements for connecting your Braze data to Supermetrics.
You need a Braze REST API key and your Braze REST endpoint to connect to Braze.
REST API key: Created in Braze under Settings → APIs and Identifiers → REST API Keys. The key must have the following permissions:
campaigns.listcampaigns.detailscampaigns.data_seriesCreating an API key requires the appropriate admin permissions in your Braze account.
REST endpoint: The REST API URL for your Braze instance, for example,
https://rest.iad-03.braze.com. The REST API URL corresponds to your Braze dashboard cluster. You select it from a list when connecting. If you're unsure which endpoint to use, see Braze's REST API endpoints (it matches the dashboard URL you log in to).
Campaign performance: message delivery and engagement metrics (sent, delivered, opens, clicks, bounces, and more) broken down by channel and message variation, per day.
Campaign analytics: campaign-level outcomes (revenue, conversions, and unique recipients), per day.
When connecting to Braze, you enter your Braze REST API key and select your REST endpoint when prompted. Braze uses credential-based authentication, so there's no separate login window.
Select the Braze data source on the Supermetrics Hub or in the data destination.
Insert your Braze REST API key and select your REST endpoint.
You can also connect to Braze from these destinations:
