Bing Webmaster Tools connection guide
This guide contains all permissions and requirements for connecting your Bing Webmaster Tools data to Supermetrics.
To connect Supermetrics to Bing Webmaster Tools, webmasters need an API key. Follow Microsoft's instructions to generate this API key.
When connecting to Bing Webmaster Tools, you need to provide your API key.
  1. Select the Bing Webmaster Tools data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key.
  4. Click Start.
  5. In your data destination, select the sites to include in your reporting and a query type, if prompted.
You can also connect to Bing Webmaster Tools from these destinations:
