This guide contains all permissions and requirements for connecting your Amazon Vendor Central data to Supermetrics.
To connect, you must be the primary user of the Amazon Vendor Central account or you have enabled Grant universal site admin access permissions for a secondary user account.
To assign admin permissions to a secondary account:
Go to Settings → Manage Permissions in Amazon Vendor Central.
Click Edit.
Under Role and Permissions, select Admin and save your changes.
Note that permissions in Amazon Vendor Central are region-locked. The account you use must be specifically authorized for the region you want to pull data for. In case you manage multiple regions, you need multiple accounts.
Sales
Traffic
When connecting to Amazon Vendor Central, you need to log in to Amazon and select the marketplace when prompted.
Select the Amazon Vendor Central data source on the Supermetrics Hub or in the data destination.
Log in to your Amazon account.
Select the marketplace account where you have the main store.
In your data destination, select the select the marketplaces you’d like to include in your reporting and a query type to use.
You can also connect to Amazon Vendor Central from these destinations:
AI tools and dashboards:
