This guide contains all permissions and requirements for connecting your Affluent data to Supermetrics.
To connect Affluent to Supermetrics, you need:
An API key
An API URL
To get your API key and API URL:
Contact your Affluent administrator to get the API key. Remember to keep the API key safe.
To get your API URL, replace
{server}in the following URL with the name of your Affluent server:https://{server}-api.affluent.io/Find your Affluent server name in your Affluent URL. For example, for the Affluent URL
accountname.affluent.io/, the server name isaccountname.Don't forget to include / at the end of your API URL.
Performance: Fetches detailed performance data for affiliate marketing campaigns.
When connecting to Affluent, you need to provide your API key and API URL.
Select the Affluent data source on the Supermetrics Hub or in the data destination.
Enter your API key and API URL.
Give your login a name to recognize the login later if you have multiple logins.
In your data destination, select a query type, if prompted.
You can also connect to Affluent from these destinations:
AI tools and dashboards:
