This guide contains all permissions and requirements for connecting your Adobe Analytics data to Supermetrics.
There are two ways to authenticate Adobe Analytics:
Connect with OAuth Server-to-Server (recommended)
Connect with OAuth
These authentication methods both work differently and have different advantages.
Authentication method | Details |
OAuth Server-to-Server |
OAuth |
Prerequisites: Connect with OAuth Server-to-Server
To connect Supermetrics to Adobe Analytics with OAuth Server-to-Server you need:
A System Administrator or Developer user role in your Adobe account organization.
Explicit access granted to see the report suites, reports, segments, and custom fields. Visit Adobe’s help center to learn how to change user roles.
When you're ready, follow our detailed guide to create the credentials and connect your Adobe Analytics account to Supermetrics.
To connect Supermetrics to Adobe Analytics with OAuth, you need:
An Adobe ID linked to Experience Cloud with Web Service Access enabled
The linked ID needs access to the report suites, reports, segments, and custom fields you want to use in your reporting. Visit Adobe’s help center to learn about granting and changing account permissions.
When connecting to Adobe Analytics, you need to select an authentication method and enter your credentials.
Select the Adobe Analytics data source on the Supermetrics Hub or in the data destination.
Select an authentication method and enter your credentials.
For OAuth, click Start and use your email address and password to log in to Adobe.
For OAuth Server-to-Server, enter the client ID, client secret, and credential name, and click Start.
In your data destination, select the accounts and segments to use in your report.
AI tools and dashboards:
Spreadsheet and visualization tools:
