Zoho CRM connection guide
This guide contains all permissions and requirements for connecting your Zoho CRM data to Supermetrics.
You need to create an application to connect your Zoho CRM data to Supermetrics.
  1. Go to Zoho Developer Console.
  2. Choose client type: Server-based Applications.
  3. In the Client Name field, enter "supermetrics".
  4. In the Homepage URL field, enter "supermetrics.com".
  5. In the Authorized Redirect URIs field, enter "https://supermetrics.com/login-complete".
Visit Zoho CRM's API documentation for more details.
When connecting to the Zoho CRM, you need to select a query type. The query type defines the metrics and dimensions available.
  • Leads report: Data on the status and performance of your sales leads
  • Deals report: Data on the progress and performance of your sales deals
  • Contacts report: Fetch details about your contacts in Zoho CRM
  • Account report: Fetch details about your accounts in Zoho CRM
When connecting to Zoho CRM, you need to log in to your Zoho account.
  1. Select the Zoho CRM data source on the Supermetrics Hub or in the data destination.
  2. Insert Client ID and Client secret.
  3. Sign in to your Zoho account.
  4. Accept scopes for the application.
  6. Click Start.
  7. In your data destination, select the query type to use.
You can also connect to Zoho CRM from these destinations:
