Yahoo DSP connection guide
This guide contains all permissions and requirements for connecting your Yahoo DSP data to Supermetrics.
To connect Supermetrics to Yahoo DSP, you need API access, including a client ID and client secret. Read Yahoo DSP's documentation to learn how to get access.
When connecting to Yahoo DSP, you need to provide your client ID and client secret and select the account to pull data from.
  1. Select the Yahoo DSP data source on the Supermetrics Hub or in the data destination.
  2. Enter your client ID and client secret.
  4. Click Start.
  5. In your data destination, select the account to use in your reporting.
You can also connect to Yahoo DSP from these destinations:
