Xandr connection guide
This guide contains all permissions and requirements for connecting your Xandr data to Supermetrics.
Before connecting Xandr to Supermetrics, you need a Xandr username and password to use the Xandr API. Take a look at Microsoft's help for instructions on how to get the credentials for the Xandr platform. Note that the Microsoft account you log in to Xandr with isn't enough for API access.
  • Advertiser report: View performance, revenue, and profit data across a specific advertiser's creatives and campaigns. This report is available to network and advertiser users.
When connecting to Xandr, you need to log in to Xandr.
  1. Select the Xandr data source on the Supermetrics Hub or in the data destination.
  2. Enter your Xandr username and password.
  4. Click Start.
  5. In your data destination, select the query type, if prompted.
You can also connect to Xandr from these destinations:
