X Ads (Twitter) connection guide
This guide contains all permissions and requirements for connecting your X Ads (Twitter) data to Supermetrics.
Your Twitter Ads account needs Campaign analyst access to pull data with Supermetrics. Some dimensions might also need Ad manager access to an ad account. Learn how to grant ad account access.
When connecting to X Ads (Twitter), you need to log in to X (Twitter) and select the accounts to pull data from.
  1. Select the X Ads (Twitter) data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Enter your credentials, and click Sign in.
  5. In your data destination, select the accounts to use in your reporting.
You can also connect to X Ads (Twitter) from these destinations:
