Wix Commerce connection guide
This guide contains all permissions and requirements for connecting your Wix Commerce data to Supermetrics.
You need an API key and your Account ID in order to connect to Wix Commerce. You can manage your API key and account ID in your Wix dashboard.
How to create an API key
  1. Log in to your Wix dashboard.
  2. Open the API keys management page.
  3. In the top-right corner, click Generate API Key.
  4. Enter a name for your API key, for example “Supermetrics”.
  5. Add the following API permissions:
    a. Basic Permissions - Get Sites List
    b. All Site Permissions - Wix eCommerce
  6. Click Generate Key.
  7. Click Send Code to send a 6-digit verification code to the email address linked to your account.
  8. Get your verification code from your email.
  9. Enter the code in the Verify your account pop-up.
  10. Click Verify and Generate Key.
How to find your Account ID
  3. The Account ID is visible on the right-hand side.
  • Orders
When connecting to Wix Commerce, you need to provide your API key and Account ID.
  1. Select the Wix Commerce data source on the Supermetrics Hub or in the data destination.
  2. Insert your API key, account ID and give a name for your connection to distinguish it later.
  4. Click Start.
  5. In your data destination, select the data to be fetched based on the created or updated date.
You can also connect to Wix Commerce from these destinations:
