Vimeo Public Data connection guide
This guide contains all permissions and requirements for connecting your Vimeo Public Data data to Supermetrics.
Vimeo Public Data allows you to collect publicly available data about content on Vimeo. It doesn't require you to log in to a specific account.
  • User data: Account metadata
  • Video data: Video metadata and basic metrics
  • Video uploads: Video metadata and basic metrics from a specific account
When connecting to Vimeo Public Data, you need select a query type and add keywords when prompted.
  1. Select the Vimeo Public Data data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. In your data destination, select your query type and add your keywords or users.
You can also connect to Vimeo Public Data from these destinations:
