TikTok Shop connection guide
This guide contains all permissions and requirements for connecting your TikTok Shop data to Supermetrics.
To authorize Supermetrics, you must be logged in with your TikTok Shop main account, as sub-accounts don't have permission to authorize services.
Follow the guided TikTok Shop’s authorization flow, and choose which shop(s) you want to authorize. Depending on your TikTok Shop setup, it is possible to authorize either one at a time or multiple from the same region at once.
Supported regions
The connector supports TikTok Shops based in the United States, Brazil, France, Germany, Indonesia, Ireland, Italy, Malaysia, Mexico, Philippines, Singapore, Spain, Thailand, the United Kingdom, and Vietnam.
Japan is ’t supported yet, but it can be added in the future.
  • Orders: Fetch detailed insights about your shop orders.
When connecting to TikTok Shop, you need to be logged in to TikTok Shop with your main account and select the region when prompted.
  1. Select the TikTok Shop data source on the Supermetrics Hub or in the data destination.
  2. Give a name for your login.
  4. Click Start.
  5. Select the desired region and click Next.
  6. If prompted, select the target shop(s).
    • Set duration for access based on your company's policies.
    • Input your contact email address.
  7. Click Confirm to install.
  8. Read through the authorizing conditions, then mark the checkbox "I acknowledge that..."
  9. Click Authorize and then Done or wait until you are automatically re-directed after 5 seconds.
  10. In your data destination, select the authorized shop(s) you would like to run queries for, and select the desired data range, metrics, and dimensions.
You can also connect to TikTok Shop from these destinations:
