Stripe connection guide
This guide contains all permissions and requirements for connecting your Stripe data to Supermetrics.
To connect Supermetrics to Stripe, you need the Administrator user role level. Learn about user roles in Stripe's documentation.
Note that you can't run queries with 2 Stripe accounts simultaneously. Log out and back in with a different account to create queries for 2 separate accounts.
When connecting to Stripe, you need to log in to Stripe and select the account to use.
  1. Select the Stripe data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Log in to Stripe.
  5. Select the account you want to use, and click Connect.
You can also connect to Stripe from these destinations:
