This guide contains all permissions and requirements for connecting your Smarp data to Supermetrics.
To connect Supermetrics to Smarp, you need:
A Smarp subdomain. This is the subdomain from your URL.
This is found after the
https://in your Smarp URL. For example, in the URLhttps: //examplestore.smarpshare.com, examplestore is the Smarp subdomain.
An API key. You'll find this in the Smarp dashboard — remember to keep it safe once you have it. Read the Authentication section of Smarp's basic concepts documentation to learn more.
An account name. This is the name you choose for your login. We recommend using your account's name.
Query types define what sort of metrics and dimensions are available. To access most query types, you'll need the Company Admin role level. You need to select one of the following query types when pulling data:
Clicks: Returns all clicks based on the period in which clicks happened.
Campaigns: Returns campaigns for a specific company.
Groups: Returns all groups within the instance.
Posts: Returns posts based on the period in which posts were published. Posts that have been deleted or were published in private channels won't be returned.
Shares: Returns all shares based on the period in which the share was done.
Teams: Returns all teams in the instance.
Users: Returns users in the company.
When connecting to Smarp, you need to give your Smarp subdomain and an API key.
Select the Smarp data source on the Supermetrics Hub or in the data destination.
Enter your Smarp subdomain and API key.
Give your login a name to recognize the login later if you have multiple logins.
You can also connect to Smarp from these destinations:
