Slack connection guide
This guide contains all permissions and requirements for connecting your Slack data to Supermetrics.
Supermetrics connects directly to your Slack workspace. When you first connect it, it'll ask for permission to view:
  • Content and information about channels and conversations
  • Content and information about your workspace
If you have any questions about how we handle and secure your data, read our security and privacy policy.
  • Channels
  • Users
  • Groups
When connecting to Slack, you need to log in to your Slack workspace and select the query type to use when prompted.
  1. Select the Slack data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. If you're not already logged into a Slack workspace, log in.
  5. Click Allow.
  6. In your data destination, select the query type to use.
You can also connect to Slack from these destinations:
