This guide contains all permissions and requirements for connecting your Shopware data to Supermetrics.
You need an Access Key ID and Secure Access Key, and your store base URL to connect to Shopware.
The Access Key ID and Secure Access Key need to have at least read-level permissions to Catalogues, Content, Customers, Orders, and Other (Sales Channels).
If you’re unable to create a new key or find your store base URL, reach out to your store admin.
How to find your credentials
Log in to your Shopware Admin panel.
Navigate to Settings → System → Integrations.
Click Add Integration.
Copy the Access Key ID and Secure Access Key
Your Base URL is your Shopware store URL (
https://your-shop.example.com).
Orders
Order items
When connecting to Shopware, you need to provide your API credentials and store base URL.
Select the Shopware data source on the Supermetrics Hub or in the data destination.
Insert connection name, base URL, access key ID, and secure access key.
In your data destination, select whether to query data based on created or updated date.
You can also connect to Shopware from these destinations:
AI tools and dashboards:
