This guide contains all permissions and requirements for connecting your RTB House data to Supermetrics.
Your RTB House account must have API access enabled in order for you to connect it to Supermetrics. Reach out to your RTB House representative to set this up.
Performance: Measure the performance of your retargeting campaigns.
Branding: Measure the performance of your branding campaigns.
When connecting to RTB House, you need to log in to RTB House.
Select the RTB House data source on the Supermetrics Hub or in the data destination.
Enter your RTB House username and password.
You can also connect to RTB House from these destinations:
AI tools and dashboards:
