This guide contains all permissions and requirements for connecting your Rakuten Advertising data to Supermetrics.
Supermetrics fetches performance data for affiliate campaign advertisers through Rakuten Advertising. It doesn't currently support the platform's publisher side.
To connect to Rakuten Advertising, you need to create a report, and then get your report key and API token. Follow the steps below to meet these prerequisites.
Step 1: Create a report in Rakuten Advertising
Log in to Rakuten Advertising.
Navigate to Reports, and then Reporting.
Select an existing report, or build a new one. Select every column that you want to use in Supermetrics. You can alter the time range and other report settings at any time in Supermetrics itself.
Save the report.
Step 2: Get your report key and API token
Open the report you want to use in Supermetrics.
Click the dropdown next to View report.
Click Get API.
You'll see your API URL. From it, pull:
Report key: Copy the string that follows /reports/ in the URL. It should match the name you gave your report.
API token: Copy the string that follows &token= in the URL.
Here's an example:
//ran-reporting.rakutenmarketing.com/en/reports/[REPORT-KEY]/filters?date_range=this-month&include_summary=Y&tz=GMT&date_type=transaction&token=[API-TOKEN]
Save your report key and API token securely.
When connecting to Rakuten Advertising, you need to provide your report API token report key.
Select the Rakuten Advertising data source on the Supermetrics Hub or in the data destination.
Enter your report API token and report key.
Give your login a name to recognize the login later if you have multiple logins.
You can also connect to Rakuten a from these destinations:
AI tools and dashboards:
