This guide contains all permissions and requirements for connecting your Quora Ads data to Supermetrics.
You need a Quora account with the Admin user role to connect to Supermetrics. Learn more about granting access to account in Quora's documentation.
When connecting to Quora Ads, you need to log in to Quora and select the accounts to pull data from.
Select the Quora data source on the Supermetrics Hub or in the data destination.
Enter your email address and password, and click Log in.
Click Accept.
In your data destination, select the accounts to use in your query.
You can also connect to Quora Ads from these destinations:
AI tools and dashboards:
