Omnisend connection guide
This guide contains all permissions and requirements for connecting your Omnisend data to Supermetrics.
To connect Supermetrics to Omnisend, you need:
  • All campaigns
  • A/B test campaigns
When connecting to Omnisend, you need to provide your API key.
  1. Select the Omnisend data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key.
  5. Click Start.
  6. In your data destination, select a query type to use.
You can also connect to Omnisend from these destinations:
