Moz connection guide
This guide contains all permissions and requirements for connecting your Moz data to Supermetrics. Moz is available in Google Sheets and Data Studio.
Moz allows you to collect publicly available search engine data. To fetch more than 200 rows of data with it, you'll need to use your own API credentials.
  • URL metrics: Returns metrics for up to 50 URLs.
  • Link metrics: Returns information about links between a target URL and other pages and domains.
  2. Navigate to Extensions → Supermetrics → Launch sidebar to open Supermetrics.
  3. Click Create new query.
  4. Under Data source, select Moz.
  6. Click Start.
  7. Navigate to Report configuration, and select a query type.
  8. Add URLs to the URLs field. Separate multiple URLs with commas and no whitespace (,).
Data Studio
  2. Navigate to Moz and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Moz requires authorization to connect to data").
  7. Click Start.
  8. Select a query type and click Next.
  9. Add URLs to the URLs field. Separate multiple URLs with commas and no whitespace (,).
  10. In the pane's top right, click Connect.
  11. Click Create report.
  12. Click Add to report.
