This guide contains all permissions and requirements for connecting your Matomo data to Supermetrics.
To connect your Matomo account to Supermetrics, you need your Matomo base URL and your authentication token.
These instructions apply to both Matomo cloud-based version and on-premise installation.
Get your base URL
Log in to Matomo and open your dashboard.
Take a look at the URL in your address bar.
The first part of the URL before
index.phpis your base URL to use for login, for example:https://yourcompany.matomo.cloud. Make sure that the URL includes thehttps://in front of it.
The base URL must be publicly accessible. If you host your own Matomo instance with a custom URL (not the standard Matomo one), it must be publicly accessible on the internet for it to work with our connector. For example, if you set Matomo to require a specific VPN to access it, the base URL won’t work with Supermetrics.
Get your authentication token
Log in to Matomo, and open your dashboard.
On the upper right-hand side, click the cogwheel icon to get to the Administration page.
On the left-hand side, under Personal, click Security.
Scroll down to the Auth tokens section and click Create new token.
Enter your password to continue.
Enter a description for the token, for example, “Supermetrics”.
Click Create token.
Copy the token and store it in a secure place for later.
Query types define what sort of metrics and dimensions are available. Set up your Matomo queries using any of the query types described below.
Reference list: Matomo query types
Visitors
Visitors: Overview: Engagement metrics for the whole website.
Visitors: Country: Engagement metrics by country.
Visitors: Language: Engagement metrics by web browser language.
Visitors: Device type: Engagement metrics by device type.
Behaviour
Behaviour: Pages: Engagement metrics by specific website pages.
Behaviour: Site search keywords: Site searches by keyword
Behaviour: Outlinks: Clicks by outlink on site.
Behaviour: Downloads: Downloads by URL.
Behaviour: Events: Engagement metrics by event.
Acquisition
Acquisition: Channel types: Acquisition and engagement metrics by channel type.
Acquisition: Referrers: Acquisition and engagement metrics by specific referrers.
Acquisition: Campaign names: Acquisition and engagement metrics by campaigns.
Acquisition: Campaign keywords: Acquisition and engagement metrics by keywords used in campaigns.
Acquisition: Search engines: Acquisition and engagement metrics by search engine.
Acquisition: Search keywords: Acquisition and engagement metrics by search keywords.
Ecommerce
Ecommerce: Overview: Overall ecommerce sales for the whole website.
Ecommerce: Products: Ecommerce sales by specific products.
Goals
Goals: Overview: Performance of custom goals.
When connecting to Matomo, you need to provide your credentials and select the accounts and query type when prompted.
Select the Matomo data source on the Supermetrics Hub or in the data destination.
Enter your base URL and auth token.
Enter a name for your account for you to identify it later.
In your data destination, select the accounts to include in your reporting and a query type.
You can also connect to Matomo from these destinations:
AI tools and dashboards:
