This guide contains all permissions and requirements for connecting your LiveIntent data to Supermetrics.
LiveIntent uses OAuth 2.0 to authenticate your connection to Supermetrics, so you'll have to set it up before you can connect. Learn more about OAuth 2.0.
When connecting to LiveIntent, you need to log in to LiveIntent.
Select the LiveIntent data source on the Supermetrics Hub or in the data destination.
Enter your LiveIntent username and password.
Click Allow.
In your data destination, select the accounts to use.
You can also connect to LiveIntent from these destinations:
AI tools and dashboards:
