Kwai Ads connection guide
This guide contains all permissions and requirements for connecting your Kwai Ads data to Supermetrics.
Before using the Kwai Ads connector, reach out to Kwai to obtain the credentials you need to access the connector. Ask your contact at Kwai to create and share with you your client ID, client secret, and refresh token.
Please note that each account has access to a specific set of Kwai datasets. Make sure that you request permissions from Kwai to all the relevant datasets you want to use in Supermetrics.
See Kwai's Supermetrics-Kwai integration manual for details about the connection steps.
When connecting to Kwai Ads, you need to provide your credentials and select the accounts to use when prompted.
  1. Select the Kwai Ads data source on the Supermetrics Hub or in the data destination.
  2. Enter the client ID, client secret, and refresh token.
  3. Give a name for your account so that you can identify it later.
  5. Click Start.
  6. In your data destination, select the accounts to pull data from.
You can also connect to Kwai Ads from these destinations:
