This guide contains all permissions and requirements for connecting your Ignite data to Supermetrics.
To connect Supermetrics to your Ignite account, you need a client ID and client secret from your contact person at RealEstate.com.au.
Campaigns: Measure the performance of your property campaigns.
Campaign creatives: Retrieve a collection of flight data for a specified campaign ID, including a daily breakdown of performance metrics.
Campaign flights: Retrieve a collection of creative data for a specified campaign ID, including a daily breakdown of performance metrics.
Aggregated project profile performance report: Retrieve total project performance reports for property advertising campaigns.
Daily project profile performance report: Retrieve daily project performance reports for property advertising campaigns.
When connecting to Ignite, you need your client ID and client secret.
Select the Ignite data source on the Supermetrics Hub or in the data destination.
Enter your client ID and client secret.
In your data destination, select a query type to use, if prompted.
You can also connect to Ignite from these destinations:
